It is currently Sat Jul 26, 2025 8:04 am
PostPosted: Mon Jun 06, 2005 2:54 pm
I'm contemplating going back to Titebond, but I have some new LMI in a shipment that I'd forgotten about. I guess I could just outfit the wife and kids with household glue for another year or so, but it got me to wondering about the thread where the LMI stuff failed. And I think John Mayes that had a couple boxes come apart routing for binding after using LMI?    Any new scares or was it just a bad batch?
Larry
PostPosted: Mon Jun 06, 2005 2:58 pm
I've used it for the last 10 or so guitars and never had a problem.
PostPosted: Mon Jun 06, 2005 3:11 pm
LMI white is fine, no actually it is a really good glue.
I can say the only centerseam that I had fail, was made with titebond on an early guitar. Was it the titebond's fault? I doubt it.
I would tend to look at process more so than product when I get a failure. Did I candle the joint, did I starve it. I won't blame the the tightbond, it is more likely I did not prep the joint the really well.
PostPosted: Mon Jun 06, 2005 3:46 pm
I've not tried it, nor wanted to, after the 3 failures (all from different
bottles and titebond worked perfectly the 4th time). I'm sure the glue is
ok, but I'm not taking my chances again. But there are a lot more praise
stories than ones like mine...
PostPosted: Mon Jun 06, 2005 10:05 pm
I've used it for all but my very first guitar, no problems at all - I would not hesitate it use it. I've never experience this, but Ive been told that Titebond has a tendency to cold creep.
PostPosted: Tue Jun 07, 2005 12:35 am
i've been using it, but not exclusively, for only a couple of years but have had no failures either in building or repair work.
PostPosted: Tue Jun 07, 2005 11:32 am
I'm just finishing up a batch of 21 guitars all of which are LMI white. No problems on 20+ before this batch either. I do keep my glue refrigerated and this may or may not help???
tim...
PostPosted: Tue Jun 07, 2005 1:48 pm
For the guys who've had the LMI glue fail...is there any chance you did your joinery in an environmental extreme: to hot/humid, or, more likely, too cold? I don't know what the chalk point of the LMI white is, but it could be a consideration in joint failure. It just seems so odd that a very few people have had a consistent problem, while others find it to be a superior product.
Carlton
PostPosted: Tue Jun 07, 2005 4:02 pm
Nope my shop is always between 65-78 degrees, and 40-50% humidity. I
think I may have gotten a bad batch... but I'd rather not risk it again. I
just prefer to stick with titebond and hide glue....
